TackMan
Jul 03, 2021Tutor
Laptop and PC refuse to connect to satellite, but can connect to Router -- advice?
Hi All, I have a very frustrating experience with one of 2 RBS850 Satellites. The Router reports the connection to both are good, most devices appear to connect to either satellite, and also to ...
Mikey94025
Aug 03, 2021Hero
Mikey94025 wrote:So for my particular setup it turns out that Double NAT prevented me from running more than one RBS850 satellite or else the network would stop working within 30 min. Note that this was true even with my secondary routers disconnected. I'm running the recent Beta firmware, with the DNS fix, but this problem has existed for me since last summer so I've kept my extra 2 satellites power down.
No, this was not the (sole) reason for my disconnecting internet problems when running more than 1 RBS850. Today my network went down a couple times and each time, was restored as soon as powering off one of the extra satellites. They had nothing connected by wired LAN, only wireless clients. Oh well, I'm back to running just one satellite.
TackMan
Aug 10, 2021Tutor
Very sorry that what looked like the solution slipped away. Unfortunatley I am out of ideas -- and your technical knowledge on network sounds like it is much better than mine! I hope you find a solution, without having to spend too many hours.
