OldChrisBailey
Nov 02, 2024Follower
laptop connects to internet but cannot connect to LAN
Orbi RBS 350 mesh, win 11, my laptop connects and operates perfectly to Wi fi through the orbi, when I attempt to log into my home Lan network the laptop is visible but unable to establish contact an...
Nov 06, 2024Guru - Experienced User
I'd remove the power line system and just connect to the RBR or RBS.
Try a factory reset on the Orbi system and setup from scratch. Use this to help you do this:
