mrwkbrdr
Jan 14, 2020Star
Laptop unable to see SSID wifi6
Lenovo laptop unable to see SSID with AX enabled. Turned of AX and SSID can now be seen.
Jan 14, 2020Guru - Experienced User
Does your laptop of an intel wireless card? If so, go to the intel site and update the driver on it. The device manufacturers (sony, lenovo, etc) aren't good at doing the update so you have go directly to whoever makes the part.
intel cards had issues with earlier drivers not being able to see ax. Try updating it.
- Chuck_MJan 14, 2020Mentor
As said previously, this is typically an issue with an outdated driver.
- mrwkbrdrJan 15, 2020Star
Driver has the latest available.
- FURRYe38Jan 15, 2020Guru - Experienced User
What is the model# of the wireless adapter card?
Do other wifi devices work while AX mode is enabled?
