mrwkbrdr
Jan 14, 2020Star
Laptop unable to see SSID wifi6
Lenovo laptop unable to see SSID with AX enabled. Turned of AX and SSID can now be seen.
Jan 14, 2020Guru - Experienced User
Does your laptop of an intel wireless card? If so, go to the intel site and update the driver on it. The device manufacturers (sony, lenovo, etc) aren't good at doing the update so you have go directly to whoever makes the part.
intel cards had issues with earlier drivers not being able to see ax. Try updating it.
Chuck_M
Jan 14, 2020Mentor
As said previously, this is typically an issue with an outdated driver.
