Rulother
Jan 10, 2022Aspirant
Last known Orbi750 firmware with telnet functionality?
So I'm needing to make my guest network a 5ghz only network and apparently I need to telnet into the orbi system in order to deactivate the 2.4ghz for it, however my firmware does not even list this ...
Jan 10, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Any changes you make in telnet will not persist thru a FW update nor a reboot.
Thank you
Rulother
Wait are you saying if I disabled 2.4ghz for the guest network in telnet, then after a reboot it will be re-enabled?
- FURRYe38Jan 10, 2022Guru - Experienced User
Correct. Why are you trying to set 5Ghz only for Guest Network?
- RulotherJan 10, 2022Aspirant
I have some devices that do not behave well on the 2.4ghz spectrum, aka a Samsung Q950T soundbar among a few. I would love to create a hidden 5ghz network.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?try turning down the power output of the RBRs 2.4Ghz wifi radios from 100% to 25% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
