Rulother
Jan 10, 2022Aspirant
Last known Orbi750 firmware with telnet functionality?
So I'm needing to make my guest network a 5ghz only network and apparently I need to telnet into the orbi system in order to deactivate the 2.4ghz for it, however my firmware does not even list this ...
Jan 10, 2022Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
try turning down the power output of the RBRs 2.4Ghz wifi radios from 100% to 25% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Wanshun
Jan 10, 2022Tutor
FURRYe38 wrote:What Firmware version is currently loaded?
I have no neighbors
