xdwt44
Apr 28, 2021Aspirant
Latency and random poor backhaul status
Hello Everybody, I recently purchased a RBR350 with two satellites and I am currently running the firmware version : V4.3.4.8_1.9.53 I am living in a 85m2 appartment with big thick swiss walls. ...
Apr 28, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
What are the walk materials made up of? Any concrete?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-t
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
xdwt44
May 06, 2021Aspirant
Hello Fury,
Thanks for your reply on this and sorry for replying late.
For some reasons, it went back as "normal" without any issue for a week or so, and now its going back to randomly poor.
I will try all the settings you mentionned.
Thanks
Jonathan
- xdwt44May 06, 2021Aspirant
I can modifiy the channel for the channel 2.4Ghz but not 5 it's greyed out.
Since I have done the following settings, my satellite are not joining anymore, even by reseting them or bringing them closer..
- tak1313May 07, 2021Luminary
Check you bufferbloat (it's that word again!) at sites such as dslreports or waveform - for example:
https://www.waveform.com/tools/bufferbloat
if it's bad, check to see if WMM is enabled.
if it is enabled, put your synology back, and use the Orbi as AP. Then use your Synology to control QOS (I hear Synology is pretty good at it).
Orbi's QOS ability is s*cks (that word again) even with their WMM. Bufferbloat affects gaming a videoconferncing more than raw speed. Because of Orbi's lack of QOS, my wife was having problems with her Zoom meetings, so I put my Asus router back in, using the Orbi as AP.
Bufferbloat went from C/D (with WMM enabled/Orbi routing) to A+/A (Asus routing / QOS enabled / Orbi AP). Wife is happy with Zoom. Happy wife=happy life.
- FURRYe38May 07, 2021Guru - Experienced User
Also can you show us the wireless settings page with the 5Ghz channel being grayed out?
You should be able to select 36 thru 48 for 5Ghz.
Try a different browser by chance?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.What are the walk materials made up of? Any concrete?
xdwt44 wrote:I can modifiy the channel for the channel 2.4Ghz but not 5 it's greyed out.
- xdwt44May 08, 2021Aspirant
My first satellite is 10m away from the router, the second satellite is roughly 15m away from the router and roughly 10m from the satelite.
Here are my settings showing the settings for 5Ghz greyed out (it's greyed out with every browsers Chrome, Safari, Firefox..)
Bufferbloat results : https://www.waveform.com/tools/bufferbloat?test-id=68752d34-4515-455d-ac00-59e91e4faeae
The second satellite (which is the one getting poor sometimes) as to cross some concrete wall.
The Netgear router is connected to a UPC router but I don't really see where this is relevant since the UPC router is in bridge mode and I don't have any problems if I am not connected to the satellite I mention having problems.
Is there not logs or anything relevant like stats that could be displayed when I am having this problems so we could say "ok this is coming from this" ??
Most of my pings are between 20-40ms and then randomly going to 150-200ms which is then causing issues with visios and even sometimes zoom showing up "your internet connection is not stable" but I don't have these latencies at the router itself as I have another laptop connected via wire and I am also testing latencies at the same time so I know my wifi is to blame.
i.e :
64 bytes from 8.8.8.8: icmp_seq=37 ttl=118 time=19.592 ms
64 bytes from 8.8.8.8: icmp_seq=38 ttl=118 time=19.833 ms
64 bytes from 8.8.8.8: icmp_seq=39 ttl=118 time=23.269 ms
64 bytes from 8.8.8.8: icmp_seq=40 ttl=118 time=20.420 ms
64 bytes from 8.8.8.8: icmp_seq=41 ttl=118 time=20.641 ms
64 bytes from 8.8.8.8: icmp_seq=42 ttl=118 time=25.141 ms
64 bytes from 8.8.8.8: icmp_seq=43 ttl=118 time=20.487 ms
64 bytes from 8.8.8.8: icmp_seq=44 ttl=118 time=25.987 ms
64 bytes from 8.8.8.8: icmp_seq=45 ttl=118 time=23.316 ms
64 bytes from 8.8.8.8: icmp_seq=46 ttl=118 time=21.869 ms
64 bytes from 8.8.8.8: icmp_seq=47 ttl=118 time=184.960 ms
64 bytes from 8.8.8.8: icmp_seq=48 ttl=118 time=140.960 ms
64 bytes from 8.8.8.8: icmp_seq=49 ttl=118 time=144.774 ms
64 bytes from 8.8.8.8: icmp_seq=50 ttl=118 time=39.193 ms
64 bytes from 8.8.8.8: icmp_seq=51 ttl=118 time=21.196 ms
64 bytes from 8.8.8.8: icmp_seq=52 ttl=118 time=19.178 ms
64 bytes from 8.8.8.8: icmp_seq=53 ttl=118 time=23.929 ms
64 bytes from 8.8.8.8: icmp_seq=54 ttl=118 time=30.520 ms
Here are the only advanced settings available to me by the way on the router :
Thanks
