xdwt44
Apr 28, 2021Aspirant
Latency and random poor backhaul status
Hello Everybody, I recently purchased a RBR350 with two satellites and I am currently running the firmware version : V4.3.4.8_1.9.53 I am living in a 85m2 appartment with big thick swiss walls. ...
Apr 28, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
What are the walk materials made up of? Any concrete?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-t
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
May 07, 2021Guru - Experienced User
Mines at 40 feet and not PINK. Too close and you get too much wifi over lap. Depends on building materials though.
