sutset
Mar 16, 2020Guide
Latest firmware drops VOIP and MS TEAMS and Skype
We need the ability to downgrade firmware without the orbi auto update. I am unable to work with all these drops. Every time they issue an upgrade they blow something out of the water. I know of no w...
Mar 16, 2020Guru - Experienced User
What Orbi product model do you have?
Is these over wired or wireless connections?
For wireless, be sure to check your CTS and RTS values. If they are at 64, please change both to 2347. Reboot both RBR and wireless devices.
If this still fails, then try this:
sutset
Mar 16, 2020Guide
I have orbi AX started right after firmware upgrade
