sutset
Mar 16, 2020Guide
Latest firmware drops VOIP and MS TEAMS and Skype
We need the ability to downgrade firmware without the orbi auto update. I am unable to work with all these drops. Every time they issue an upgrade they blow something out of the water. I know of no w...
Mar 20, 2020Guru - Experienced User
Any progress on this?
This issue should be resolved. NG has fixed behind the scenes problems that were effecting v10.11FW. Please re-apply v10.11 and factory reset the RBR and setup from scratch.
Your problems should be gone. Let us know.
sutset wrote:We need the ability to downgrade firmware without the orbi auto update. I am unable to work with all these drops. Every time they issue an upgrade they blow something out of the water. I know of no way to keep a lower firmware without Orbi auto updating
TURBOGUARD
Mar 20, 2020Tutor
FURRYe38 wrote:This issue should be resolved. NG has fixed behind the scenes problems that were effecting v10.11FW. Please re-apply v10.11 and factory reset the RBR and setup from scratch.
I really hope so. Am going to hook it up right now and update.
- FURRYe38Mar 20, 2020Guru - Experienced User
Let us know. I recommend doing a factory reset and setup from scratch on the RBR after v10.11 is applied.
- sutsetMar 20, 2020Guide
We still need an option to disable auto update. NG’s track record on giving their customers good firmware is sitting around ZERO Percent. This country in the biggest crisis of our lifetime and we are all working from home and need 100 percent reliability. NG cannot provide that but they can provide us with an option not to auto update so that we are empowered to update when we want and we are not forced by NG to load software never works.
I’ll try an upgrade tonight.- FURRYe38Mar 20, 2020Guru - Experienced User
Let us know how it goes.
