kingharrison
Sep 30, 2021Aspirant
Latest Firmware (V4.6.3.16) Broken My Internal Static Routes To Site To Site Tunnel Device
The latest firmware update has broken my static routes to my I have the Orbi serving the internet / wifi for my house. For business purposes I have a Fortigate 30E that has one port on the inter...
Sep 30, 2021Guru - Experienced User
Is Armor or Smart Parental controls enabled?
kingharrison
Oct 02, 2021Aspirant
Yes, I have done a factory reset and setup from scratch.
I do not use armor or parental controls.
- FURRYe38Oct 02, 2021Guru - Experienced User
You can down grade the RBR normally, however to downgrade the RBR, follow this:
Can you use your Fotigate to block update services for Orbi?
TCP port 443 (HTTPS): http.fw.updates1.netgear.com
TCP port 21 (FTP): updates1.netgear.com- kingharrisonOct 06, 2021Aspirant
Thanks! Where do I download a lower firmware and how do I stop automatic updates?
- FURRYe38Oct 06, 2021Guru - Experienced User
https://www.netgear.com/support/
