chichuen
Jan 19, 2020Aspirant
Latest Orbi wifi 6 RBK852 difficulty connecting 2.4 Ghz devices
Bought the latest wifi 6 Orbi router with satellite - was not able to get 2.4 and 5 Ghz bands - talked to the Netgear tech and understood the router auto selects - when i asked how to connect devices...
chichuen
Thanks for ur response...when u say same 2.4 ghz name and pw, you mean old router to be active? When I connected the Orbi, I disabled the old router wifi...
Chuck_M
Jan 20, 2020Mentor
Disabling the wifi is not enough... you have to actually bridge the old router (or take it out of the architecture).
Is this what you meant to say that the old router is still upstream of the Orbi AX?
- chichuenJan 22, 2020Aspirant
sorry. i was using Google supplied modem **bleep** router using its 2.4 Ghz to connect the such devices. With Orbi Mesh RBK 852, i disabled Google modem **bleep** router wifi. when i tried to connect Ringpro camera doorbell, it started hanging.
- FURRYe38Jan 22, 2020Guru - Experienced User
Does it hang if you disable AX mode on the RBR?
