murtski
Apr 08, 2023Aspirant
LBR20 connect to RBR840 Satellite
I set up a mesh wi-fi with RBR840 with router and 2 satellites. I have a LBL20 modem and one satellite that I am no longer using. I tried to use one of the RBR840 satellites to provide internet to t...
Apr 09, 2023Guru - Experienced User
That would be no:
murtski
Apr 09, 2023Aspirant
Just to clarify, I'm not trying to connect the LBR20 to the wi-fi network of the RBR840, I'm trying to set up a separate wi-fi network using internet from the port on one of the satellites. That works, but when I have the LBR20 plugged into the RBR840 satellite, the RBR840 satellite goes offline.
- FURRYe38Apr 09, 2023Guru - Experienced User
Check to see if the LBR supports AP mode, if it does, you could see if AP mode works in this configuration.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-ModeOthers while would not be recommended. The 8 series system should work well for your needs.
