ThomHC06
Apr 14, 2025Tutor
Livebox and Orbi RBK752 - RBR750 & RBS750
Hello, I currently have a Livebox and an RBK752 pack, and I wanted to know if I could modify my installation as shown in the following diagram so that the router and satellite are connected via Ethe...
- Apr 16, 2025Hello ThomHC06,
Thanks for the visual diagram!
The only way that configuration will work is if the switches are managed switches and can use access and trunk protocols on the connecting RJ45 ports. This will be to ensure that the ports have to correct protocol configured for the RBR750 to gain access to the internet from the LiveBox. The port that connects to the satellite will need to be configured for the satellite to gain internet access from the RBR750. This configuration is complex and will require expertise.
I recommend simplifying your network topology by doing the following:
Connect the switch connected to the RBR750 from the LAN port to the RBS750.
Remove the switch that connects the live box if possible and directly connect the LiveBox to the LAN port.
Best,
Kevin
Community Team
KevinLiT
Apr 16, 2025NETGEAR Moderator
Hello ThomHC06,
Best,
Kevin
Community Team
Best,
Kevin
Community Team
