Bradmacozoz
Oct 07, 2023Aspirant
Local Loopback RBR350?
Local loopback isn’t available on a RBR350, is this correct? current running the lastest firmware. If so when will Netgear install this into their firmware. Not having this available is like wo...
- Oct 07, 2023
Hi CrimpOn,
It's fixed!.
The PORT FORWARDING was forwarded to the server IP with TCP only, changed it to TCP&UDP and suddenly i was able to access the website and the security cameras. Seems like I was mistaking about Orbi and it's abilities.
What a strange way of doing it!... you agree?
Thanks
Brad
Bradmacozoz
Hi CrimpOn,
It's fixed!.
Thanks
Brad
michaelkenward
Oct 08, 2023Guru - Experienced User
No.
A classic case of posing the wrong question.
Tell people what you want to achieve – "access the website and the security cameras". Don't ask why your solution – "local loopback isn’t available" – doesn't work.
- CrimpOnOct 08, 2023Guru - Experienced User
NAT Loopback is a convenient way to test port forwarding. My usual method is a lot more work:
- Disconnect cell phone from LAN
- Open Hot Spot on cell phone
- Disconnect laptop from LAN
- Connect laptop to Hot Spot
- Test port forwarding by connecting to public IP address
- After test, shutoff Hot Spot
- Reconnect cell phone to LAN
- Reconnect laptop to LAN
I'm not surprised that security cameras might need a UDP connection.
