FANOFTHE9
Nov 20, 2022Follower
Location of mounting holes on bottom of RBS760 vs location on RBS750?
How does the location of the mounting holes on the bottom of the RBS760 compare with the location of the mounting holes on the bottom of the RBS750? Background: I cannot find wall mounting bracke...
Nov 20, 2022Guru - Experienced User
I believe the case style is different from the 750 series.
https://www.downloads.netgear.com/files/GDC/RBK763S/RBK763S_DS.pdf
So I can only presume that the bottom screw holes maybe slightly different locations on the bottoms.
CrimpOn
I agree with FURRYe38 that the 750 and 760 are definitely "different":
RBS750:
RBS760:
Many of the current wall mounts on Amazon have a design that lends itself to "drill your own holes" if the bracket does not line up exactly with the case, such as this one:
This one looks like the mounting screws are almost redundant:
