FANOFTHE9
Nov 20, 2022Follower
Location of mounting holes on bottom of RBS760 vs location on RBS750?
How does the location of the mounting holes on the bottom of the RBS760 compare with the location of the mounting holes on the bottom of the RBS750? Background: I cannot find wall mounting bracke...
Blanca_O
Nov 22, 2022NETGEAR Employee Retired
Hi FANOFTHE9
The RBS760 doesn’t have mounting holes. It is much smaller than the RBS750.
If you have the RBKWM (Orbi Wall Mount Kit), you would need to use the cradle which is used for smaller Orbi models.
To know more: https://www.netgear.com/support/product/rbkwm.aspx#docs
Blanca
Community Team
