miniz98
Dec 30, 2022Aspirant
Log file empty
Hello my log file on rbr850 is blank no matter what options I pick it shows nothing on the admin screen. This is a must for my business. I've restarted the router and still blank. Latest update as wel...
- Jan 02, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
miniz98
Dec 31, 2022Aspirant
Thanks a million. App specific worked. Happy new year.
Jan 02, 2023Guru - Experienced User
Enjoy. 📡
