mikeubell
Dec 27, 2022Aspirant
login nolonger works RBR750
My system has been installed for about a month. I have logged in and set a password on the web admin interface and set many advanced options. Suddenly I can no longer log in. My phone app is still...
mikeubell
Thanks for responding but I was looking for anything else I could do prior to reset. I have the info on my configuration, but I just want to try to avoid the hassle. Also is this a common problem where login stops working?
Dec 27, 2022Guru - Experienced User
No common, however have seen it before.
If you never setup security questions or have done a factory reset and didn't answer the questions, you'll need to run thru this and get the information added so a recovery option can be used correctly. Thats why recovery is not working for you.
