fakkerma54
Nov 19, 2024Aspirant
Login to Orbi router
Since 3 years it has not been possible anymore to login on my desktop PC to my Orbi 850 Series Tri-Band WIFI 6 Mesh, model RBR850. Added is one functioning satellite, model RBS850. Operating system: ...
- Nov 29, 2024
After any factory reset, you can be sure to use the same SSID name that you had been using before so that prior connected devices will reconnect and you won't have to set them up again.
Sounds like you have a router upstream from the RBR thats using 192.168.1.1 in which the RBR will auto change to 10.x to avoid this conflict as two routers can not use the same IP address while on the same line.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
CrimpOn
Nov 19, 2024Guru - Experienced User
How are you attempting to log into the Orbi with a web browser?
- Using a URL, such as http://orbilogin.net , or
- Using the IP address which the Genexis has assigned to the Orbi router (base unit)?
