fakkerma54
Nov 19, 2024Aspirant
Login to Orbi router
Since 3 years it has not been possible anymore to login on my desktop PC to my Orbi 850 Series Tri-Band WIFI 6 Mesh, model RBR850. Added is one functioning satellite, model RBS850. Operating system: ...
- Nov 29, 2024
After any factory reset, you can be sure to use the same SSID name that you had been using before so that prior connected devices will reconnect and you won't have to set them up again.
Sounds like you have a router upstream from the RBR thats using 192.168.1.1 in which the RBR will auto change to 10.x to avoid this conflict as two routers can not use the same IP address while on the same line.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
fakkerma54
Nov 20, 2024Aspirant
RBR850
App version: 2.41.2.4183
Firmware version: v7.2.6.31
Failed attemps to login to Orbi router:
1) orbilogin.net and orbilogin.com
2) http://10.0.0.1 and http://192.168.1.1
CrimpOn
Nov 20, 2024Guru - Experienced User
When a customer owned router is in the default 'router' mode, it typically creates a local IP subnet (LAN) and assigns itself the IP address of 192.168.1.1 or 10.0.0.1 When in 'access point' mode, the router receives an IP address from the primary router and is unlikely to be assigned one of those IP addresses.
I can think of two ways to learn the IP address of the Orbi:
- Use the management system of the Genexis router to learn what IP address it has assigned to the Orbi device.
- Use a network scanning program to list all the devices on the IP subnet. Many of these programs are able to identify the brand of device and what sort of device each is.
As FURRYe38 pointed out, it is unlikely that there is "no router". If the Genexis is in bridge mode and the Orbi is in access point mode, then the system will not function at all.
