fakkerma54
Nov 19, 2024Aspirant
Login to Orbi router
Since 3 years it has not been possible anymore to login on my desktop PC to my Orbi 850 Series Tri-Band WIFI 6 Mesh, model RBR850. Added is one functioning satellite, model RBS850. Operating system: ...
- Nov 29, 2024
After any factory reset, you can be sure to use the same SSID name that you had been using before so that prior connected devices will reconnect and you won't have to set them up again.
Sounds like you have a router upstream from the RBR thats using 192.168.1.1 in which the RBR will auto change to 10.x to avoid this conflict as two routers can not use the same IP address while on the same line.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Nov 21, 2024Guru - Experienced User
You'll need to factory reset the RBR and setup from scratch with a wired PC and web browser as mentioned below using that process.
fakkerma54
Nov 23, 2024Aspirant
After a new factory reset of both the Orbi router and satellite, setting up the whole system again via the Orbi app, login to the router still proved to be impossible. It appears, in this respect, nothing has changed for the better. Any other options to consider, please?
- FURRYe38Nov 23, 2024Guru - Experienced User
Try factory reset and setup using a wired PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
- fakkerma54Nov 27, 2024Aspirant
I did try a new factory reset and setup of the Orbi router using my wired PC and web browser, but, as said, to no avail.
However, there is something positive to add to my earlier failed attempts to login to the Orbi router using my wired PC.
Last Monday, all at a sudden, I managed by accident to login to the Orbi router using my Android phone via ip-address 10.0.0.1. The Netgear page that opened was hardly visible with faint text on a light background. I had to enlarge it to make it readable.
First I had a look on the Netgear page and managed to change some simple setings that I think can be useful for my home network. However, then, after a interruption of about 3 years, I found the place where to select the desired router mode instead of the current AP mode. I did select the router mode, saved it, but, unfortunately, after a minute or so, the attempt proved to be unsuccessful. I got a long error code. I tried twice to change to the router mode on my phone, both failed.
Besides, trying to open the Netgear page again on my phone via default IP 10.0.0.1, this does not work anymore today.
The error says that the site/page does not open.
Any other suggestions are welcome.
- FURRYe38Nov 27, 2024Guru - Experienced User
So did you try to factory reset the RBR with out it connected to the ISP modem/ONT? Then try to access the RBRs web page at 192.168.1.1 to get a set wizard here?
- fakkerma54Nov 29, 2024Aspirant
I did not yet try the suggesting option to reset the RBR without connection to the ISP/ONT modem.
From my desktop PC I still cannot login to the RBR using 10.0.0.1 or 192.168.1.1.
However, since I got access to the Orbi router, perhaps one-time, using 10.0.0.1, as mentioned earlier, I could change a few things and also selecting the 'router mode' instead of the 'AP mode', but not finalizing the latter, the home network, both Wi-Fi and ethernet (using powerline adapters), as a whole, seems more stable and fast.
After each reset of the RBR not only the Orbi router had to be reinstalled and reconfigered again, but also all other Wi-Fi related devices, such as the heating system (heat pump), speakers, tv's, radios, electric curtains and even a fridge. This whole operation takes much time and effort. Therefore, I have decided to leave the RBR alone, for the time being, and to enjoy the functionality of many related devices. Only, the IP cameras are still not functioning.
Thanks for all advices and tips.
- FURRYe38Nov 29, 2024Guru - Experienced User
Couple of options,
Enjoy. 📡 - fakkerma54Nov 30, 2024Aspirant
About the, in my case lenghty, Orbi Wi-Fi reset procedure, I had indeed chosen to change the SSID in order to be able to start with a clean network system again.
Last evening I was more lucky, when using my rather old Dell laptop, using Wi-Fi to go to orbilogin.net, which, after years, suddenly succeeded, without the prior need of having used one or more of the options mentioned first.
This meant that, finally, I could now succesfully select the 'router mode' instead of the 'AP-mode'. And also backed up the configuration to file.
For as long as it takes, I have now succeeded in changing the Orbi router settings to my satisfaction.
Thank you so much. Kind regards.
- FURRYe38Dec 02, 2024Guru - Experienced User
Glad you got it working.
Enjoy. 📡
