Supertramp2
Feb 21, 2024Star
Logitech Squeezebox not connecting to RBK852
Hello, I recently got the Orbi RBK852 to replace the Orbi RBK50. All works good except that my Squeezebox Touch (2x) cannot keep a stable connection and becomes unusable. I have been sear...
- Feb 21, 2024
Checking some online research, seems that this particular device is from around 14 years ago. So standards then and how they were implemented by the Mfr would have to be changed by the Mfr, not by NG.
Also noticed that one PDF I found for this mentions WEP encryption. "Squeezebox Touch follows the 802.11 standard and uses hexadecimal keys for WEP encryption. WEP keys are 10 characters or 26 characters (for 64-bit and 128-bit encryption, respectively)."
WEP was something that was good up to one point in time, years ago, however became compromised and superseded by WPA and WPA2, thus across the board, some model routers and device mfr's stopped including this form of security in devices and firmware in later years. I believe the 50 series still had it back then since Orbi first appear around 2016. Current Orbi AX systems have never supported WEP. So maybe one reason why the AX mode suggestion didn't work on Orbi AX system as your device maybe only supported WEP encryption and not WPA2. Something to check with, however I see the Mfr has discontinued this model anyways. I doubt they will be doing anything regarding this.
Only think you might try is find you a older generation router or WIFI AP from that era or with in 5 years of that era, has WEP support, and it up as a separate WIFI system behind the Orbi AX system. Or find you a newer alternative to a device that's kind of out of date for newer WIFI systems.
Feb 21, 2024Guru - Experienced User
Or simply use the old rbk in access point mode. You'd only need the router. Set it on a different channel/ssid to prevent interference and just connect the squeezebox to that.
Quite a bit more power than it needs as any old 2.4ghz router would work
Supertramp2
Feb 21, 2024Star
That is another possible solution.
My dream solution would be that Netgear makes the RBK852 truly compatible with older wifi standards and that disabling the AX features for the 2.4 ghz network in actual fact disables these features. The other user had it working using older firmware so I am still hopeful that a next firmware would solve this. The RBK50 needed many updates before it became a solid mature router, so who knows.
