bullm00n
May 12, 2023Virtuoso
Logs Cleared on Restart - why?
Why are the logs on the Orbi being cleared on restarts? I am having some odd random restart problems - similar to this post: https://community.netgear.com/t5/Orbi-Wi-Fi-5-AC-and-Orbi-with/Orbi-rebo...
RafS
May 12, 2023Apprentice
I've had random restarts on my RBKE963 system for a while now and the only thing that solved it for me was going back to firmware 6.3.7.5 Absolutely nothing else worked and the weirdest part of all of it, I checked the logs on the two firmwares I was running after 6.3.7.5 and both of them were filled with hundreds of DOS Attack logs but after going back to 6.3.7.5, the system became stable, running a week now without a single reboot, where I was having at least 2 a day before, AND there is absolutely no signs of any DOS Attacks in the logs. I don't know what to make of all this but I'm not upgrading the firmware on on these things anytime soon. And before anyone asks, yes, the installs were all clean, no restore was done, power down was performed. Only issue I ran into when going back to 6.3.7.5 was syncing the satellites back to the router but after doing a reset via the reset button on each satellite, the satellites did finally sync back up to the router.
- bullm00nMay 12, 2023Virtuoso
RafS wrote:I've had random restarts on my RBKE963 system for a while now and the only thing that solved it for me was going back to firmware 6.3.7.5 Absolutely nothing else worked and the weirdest part of all of it, I checked the logs on the two firmwares I was running after 6.3.7.5 and both of them were filled with hundreds of DOS Attack logs but after going back to 6.3.7.5, the system became stable, running a week now without a single reboot, where I was having at least 2 a day before, AND there is absolutely no signs of any DOS Attacks in the logs. I don't know what to make of all this but I'm not upgrading the firmware on on these things anytime soon. And before anyone asks, yes, the installs were all clean, no restore was done, power down was performed. Only issue I ran into when going back to 6.3.7.5 was syncing the satellites back to the router but after doing a reset via the reset button on each satellite, the satellites did finally sync back up to the router.
Interesting to know. I wonder if I can revert to that firmware. I have never had any other firmware and whatever came from the factory got upgraded to the latest release during the setup and I don't recall having a choice about that.
I also have my 850 system. I could fall back to that for a week to monitor the situation and I may have to do that.
- FURRYe38May 12, 2023Guru - Experienced User
You can downgrade, just downgrade the RBS first before the RBR.
There should be a disable auto update check box I believe.
