mjposner
Jan 23, 2023Aspirant
Logs full of DHCP IP to MAC address
My logs are full of dhcp requests: [DHCP IP: (192.168.1.47)] to MAC address 06:C2:5A:6A:57:F5, Monday, Jan 23,2023 07:50:26 [DHCP IP: (192.168.1.54)] to MAC address C8:9E:43:44:5B:9D, Monday, Ja...
mjposner
What Firmware version is currently loaded? V4.6.14.4_2.3.12
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? The Orbi CBR750 is the cable modem
What is the size of your home? Sq Ft? 3800
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS
way more than 30 feet.
You'll need to find out what .47 is coming from. Is something on your system that is being connected to the Orbi system. What all do you have connected?
192.168.1.47 popped up in the device list, its a directtv box
Jan 23, 2023Guru - Experienced User
Is the Direct TV box wireless or ethernet connected to the CBR?
One or two RBS deployed?
- mjposnerJan 23, 2023Aspirant
Directtv box is via ethernet
4 sats
- FURRYe38Jan 23, 2023Guru - Experienced User
Try setting an IP address reservation on the CBR for the DirectTV device?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
4 RBS in that size of home, maybe too many RBS. The CBR and just 1 RBS will work.
Too Much Wifi: https://youtu.be/UR0viMLISz4
I get away with a CBR and just 1 RBS in my 5000sq ft home 3 levels including basement where the RBS gets deployed.
- mjposnerJan 24, 2023Aspirant
I tried that 1/1 and just didn't get enough signal. House is very long and old and built like a tank (1937)
