DCP4971
Jan 09, 2023Luminary
Logs show repeated assign of IP to Mac Address
Hi all, Sorry if this has been asked previously, but I couldn't find anything through searches. (Setup: RBK853 running FW V4.6.14.3_2.3.12 in router mode, behind a Sagemcom F3896LG-VMB ISP mo...
Jan 09, 2023Guru - Experienced User
What devices are these addresses going too? Apple? Android? IoT?
- DCP4971Jan 09, 2023Luminary
Thanks for the reply.
It's all sorts. Just been through one cluster of lines in the logs and it covers the following;Security Alarm
Sony Android TV
Apple Watch
Nintendo Switch
MacMini
Sonos Play 1
SkyQ TV box
HP Printer
iPad
PS5
Apple Time Capsule..
- FURRYe38Jan 09, 2023Guru - Experienced User
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️What's the current default IP address range .2 to .254?
Might change this to .100 to .200.
Is IPv6 enabled or disabled?
