DCP4971
Jan 09, 2023Luminary
Logs show repeated assign of IP to Mac Address
Hi all, Sorry if this has been asked previously, but I couldn't find anything through searches. (Setup: RBK853 running FW V4.6.14.3_2.3.12 in router mode, behind a Sagemcom F3896LG-VMB ISP mo...
Jan 09, 2023Guru - Experienced User
What devices are these addresses going too? Apple? Android? IoT?
DCP4971
Thanks for the reply.
It's all sorts. Just been through one cluster of lines in the logs and it covers the following;
Security Alarm
Sony Android TV
Apple Watch
Nintendo Switch
MacMini
Sonos Play 1
SkyQ TV box
HP Printer
iPad
PS5
Apple Time Capsule..
- FURRYe38Jan 09, 2023Guru - Experienced User
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️What's the current default IP address range .2 to .254?
Might change this to .100 to .200.
Is IPv6 enabled or disabled?
