mabwa's avatar
mabwa
Looking for clear difference between Orbi WiFi 6 System (RBK853) AX6000 and the RBK852
am abit lost, am looking to buy Orbi, but am lost, whats the difference between
Orbi WiFi 6 System (RBK853) AX6000 and RBK852 — Orbi WiFi 6 System AX6000.
Considering RBK853 is priced at $999 and RBK852 priced at $699?
Is it the same thing, only that RBK853 has 2 satelite?
  • 3 comes with 2 RBS, 2 comes with just 1 RBS. otherwise, everything is the same.
  • FURRYe38's avatar
    • mabwa's avatar
      mabwa
      Thank you. I tried to find if there is anything more different, but couldnt find apart fromt he satelites.. Thanks
