wbarnes4393
Jul 16, 2020Aspirant
Looking for consistent speed - RBK853
RBK853 - looking for consistent speed I have had the RBK50 for the past year or two and it’s been great. I’ve also had 150/150 fiber service from Frontier. I’ve generally gotten at or close to thos...
Jul 16, 2020Guru - Experienced User
Wide variance is due to mfr wifi devices and how they are designed and supported.
AC devices will max out at around 400-500Mpbs. AX, depending, should see near 900Mpbs if the connection rate is in AX mode.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
- wbarnes4393Jul 16, 2020Aspirant
Looks like the Firmware is V3.2.15.25_1.3.15.
The Orbi is connected directly to the FiOS ONT (Optical etwork Terminal) via ethernet - no intervening modem (so, I guess that IS the "modem"). It's an Alcatel-Lucent I-211M-L.
- FURRYe38Jul 16, 2020Guru - Experienced User
Ok, just checking for a router with in the modem or FIOS unit. No router I believe.
I presume your wire speeds are good.
You can update to v32 if you wish and see if this helps with anything.
May not as again, wifi speeds depend on what your wifi devices support. And if you have any AX supporting devices.
