b33k
Aug 19, 2021Tutor
Looking for help for LACP/Vlan configuration for RBR750/CM2050V/GS110EMX
I have the following equipment all Netgear GS110EMX switch, Orbi RBR750, CM2050v Modem. What I have been trying to do is use the GS110EMC switch to create a seperate VLAN2 (Port based) with just the...
Aug 19, 2021Guru - Experienced User
Please refer and post about this over in the manage switch forum:
https://community.netgear.com/t5/Managed-Switches/bd-p/business-managed-switches
Good luck.
b33k
Aug 19, 2021Tutor
Thanks, I debated on where to post it but I was guessing the issue is with the Orbi but I'll try.
