Whendingo
Sep 21, 2020Follower
Looking for recommendation - Mesh network
I'm just looking for a simple mesh solution. I need at least one device that is outside however. All the orbi packages etc are all inside devices. I'm not a networking guy - just looking to pl...
Sep 21, 2020Guru - Experienced User
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Do you have support or AX wifi?
https://community.netgear.com/t5/Orbi/Find-Your-Orbi-With-the-NEW-Orbi-Product-Selector/m-p/1907267/highlight/true#M91216
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-Systems
Orbi AX doesn't have a outdoor satellite at this time. Orbi AC system does, RBS50Y which works outdoors.
