carvi18
Nov 12, 2020Aspirant
Losing internet on computer when switching between satellites
Each time I move around my home with my computer (and switch between satellites), I lose internet connection and need to wait several minutes before I can reconnect to the Orbi WIFI network (Tri-band...
Nov 12, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
- carvi18Nov 12, 2020Aspirant
What Firmware version is currently loaded? V3.2.16.6_1.4.4
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Xfinity Wireless 3 Gateway (Model #CGM414OCOM Vendor Technicolor)What is the size of your home? Sq Ft? 3,800 sq ft
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. 30 feet or more for both satellites
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.2.4G Channel Auto (2) 2.4G Wireless mode: Up to 573.5 Mbps 5G Channel 36 + 40 + 44 + 48(P)
Any Wifi Neighbors near by? If so, how many? Only one neighbor with Wifi- FURRYe38Nov 12, 2020Guru - Experienced User
What is the distance between the your PC and each RBS?
What mode is your modem working in? Router or modem only mode? If router,
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopAlso try chaning to manual channels...
- carvi18Nov 12, 2020AspirantI did all of the things suggested below, but when I moved the computer from basement to first floor, I lost internet connection.
Thanks for all the help, any other suggestions?
