Edwardlotz
Aug 16, 2020Guide
Losing Wi-Fi internet connection on rbr850 system
I have the rbr850 system. I lose the WiFi internet connection on bot units router and satellite several times per week. All direct wired connections to the router continues to have an internet connect...
Aug 16, 2020Guru - Experienced User
Edwardlotz wrote:
I have the rbr850 system. I lose the WiFi internet connection on bot units router and satellite several times per week. All direct wired connections to the router continues to have an internet connection. I have to reboot the router to get Wi-Fi internet connection to work again.
My firmware is v3.2.15.32. On both units.
Any thoughts on what to do?
Edwardlotz
Aug 16, 2020Guide
I have a duplex so the touter is in my unit and the satellite is in my tenets. The sq ft is about 900 rack. Based on direct distance between the two units would be about 30 ft.
I had problems when setting up the satellite and router I usually like to change my channels to try and get the best. Well I was still in warranty and was on the phone for hours trying to get the satellite to connect. The rep changes all mr settings back so he said thaet where needed like they were set. 2.4 is set at auto and 5 is set at 48.
Also I live on a small island and there are houses and condos etc all over. I probably get a minimum of 6-8 WiFi networks I can join.
I hope this all helps.
- thsiaoFeb 05, 2021AspirantI have this same issue except my hard wired connections are also lost when this happens. So frustrating.
- FURRYe38Feb 06, 2021Guru - Experienced User
Any progress on this?
