Iantull
Feb 23, 2023Guide
Lost both Satellites when changing from Router to AP RBR850
I had my RBR850 configured as a router and have 2 x RBS850's attached and they were working fine. I recently change the configuration on the RBR850 from Router to AP as I am using a different router ...
- Feb 24, 2023
They are both running over wireless and from the primary router it is going to one of the Orbi's LAN ports. I didn't think to try it from the WAN port but will try that today.
michaelkenward
Feb 24, 2023Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
