Iantull
Feb 23, 2023Guide
Lost both Satellites when changing from Router to AP RBR850
I had my RBR850 configured as a router and have 2 x RBS850's attached and they were working fine. I recently change the configuration on the RBR850 from Router to AP as I am using a different router ...
- Feb 24, 2023
They are both running over wireless and from the primary router it is going to one of the Orbi's LAN ports. I didn't think to try it from the WAN port but will try that today.
Iantull
Feb 24, 2023Guide
Feb 24, 2023Guru - Experienced User
Correct, in ap mode the primary router should run to the Orbi router's wan port.
- IantullFeb 24, 2023Guide
That solved my problem, thanks for the responce, I really appreciate it.
Ian
- FURRYe38Feb 27, 2023Guru - Experienced User
Enjoy. 📡
