Howarct
Aug 17, 2020Follower
Lost Ethernet and wifi to my office computer.
For some reason the board didn't recognize the Orbi RBS850 sattellite or the RBR850 router but anyway I have the lastest firmware updates on both. The problem started when my windows 10 tried to upd...
Chuck_M
Aug 18, 2020Mentor
Sounds to me like a windows issue -- vice an Orbi issue --- I'll bet the failed windows update disabled or rolled back your ethernet drivers.
Can you open your device manager and check the status of that ethernet adapter to ensure it is functioning properly? If it is, try and update the drivers for it manually.
