TAB_17
Mar 23, 2023Follower
Lost Power... Now MAJOR ISSUES
Hello, Every single time we lose power our Orbi gets somehow messed up and causes a headache for us. It will connect to the desktop (wired) just fine and connects back to NO wireless points....
Mar 24, 2023Guru - Experienced User
What Firmware version is currently loaded on the CBR gateway and RBS satellite?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
