roxyroo's avatar
roxyroo
Tutor
Jun 14, 2022
Lost satellites on 853 system - help please
Something happened after unplugging router to move wires and can't get either of my satellites to connect.  Have tried everything and at a total loss.  At first the router showed the two satellites b...
  • TC_in_Montana's avatar
    Jun 14, 2022
    roxyroo
    Sorry to hear you are having issues.   The normal "Guru" FURRYe38 is away for a couple of days - hoping I can help you out here.
    I understand that neither of your satellites are reconnecting to the router after you did a little "rearranging", and you have one that was normally connected wirelessly, one wired - and that you did a pin-hole reset on the satellites.   You mention the lights on the satellites turn blue but are not showing up as "connected" which is quite unusual.
    While you said you had an Orbi 853 - you didn't mention the type of modem/ont you have (ISP device you get your internet service through).
    I would try the following steps:
    1)  Turn off the modem/ont (if you can) and Turn off (un-plug) both of the satellites and the router for a few minutes (maybe 5).
    2)   Turn on the modem/ont and let it fully power up.
    3)  Turn on the router and let it fully power up and connect.  (Do NOT power on any satellites yet).
    4)   Verify that while you were moving the router you plugged the cables back in fully and in the correct place (the cable from the modem should go into the YELLOW port, any other cables including the one you use for the wired connection to the satellite can go into any of the other ports.
    5)   Once router is fully up (you should be able to log into the router's admin page at 192.168.1.1) and see what devices (if any) are connecting to your router.  Unless you have a huge house - or one that is not very conducive to wifi signals - the devices you have should connect to the router (at least more than 9 of the 80).   You may want to verify that your network settings are what you had set them to originally.  Unplugging should not have caused any settings to be reset/changed unless you did a pin-hole reset on the router itself.
    6)  If you can, I would bring both satellites back into the same room as the router, and one at a time, power up and resync wirelessly.  (Once up - press the button on the back of the satellite (I usually press for about 5 seconds), then press the button on the back of the router (for about 5 seconds) - and give it a few minutes to go through the sync process.    You can also try the "add a satellite" process from the web UI as well.    Once done with one satellite, do the same for the other satellite).
    7)  Once both have resyncd, you should be able to unplug the satellites, and take them back to their original locations, turn them on - and they should "good to go".
    Hopefully this resyncs both of them with the router and gets you back up and running.   If not - we can try some other things.
