Jjersey63
Apr 29, 2022Apprentice
Lost web access to Orbi router - RBR750
I generally login to my router daily - I noticed last evening the Orbi was rebooting - I didn't reboot it but now I can no longer web into it or use the app to access the interface. I can still p...
Jjersey63
May 14, 2022Apprentice
So here is the latest for me - I need internet for remote work - no downtime or very little. Since it’s not clear to me a factory reset will work, I dropped another $600 for a “plan b”.
I spoke to another geek and he had the same issue as me. Internet was fine, just no web/app access to router. He factory reset his and he never could access the router, essentially it bricked.
So I spent another fortune and will hope I don’t need to open the box and just return it to Costco but I need an alternate plan if this goes so south. If I brick my router, is Netgear going to compensate me and others? I’ve been doing IT work for over 40 years, this ain’t my first rodeo and I can understand why Netgear would push security updates (because most users never check once it’s setup) but that isn’t me. I plan all my patch updates - backup files, blackout plans etc. and to have a forced update without warning is flat out wrong. Checksum are validated, ensuring download site vs. what is downloaded is good before I start. Not sure what was done during this update, but geez give me the chance to plan this before NG jams this down my router.
So I have the firmware that is on the web site staged, will try to factory reset tomorrow morning and see what gives.
May 14, 2022Guru - Experienced User
Factory reset with the RBR and a wired PC should bring access to the RBRs web page. Just walk thru the setup wizard in a web browser. DO NOT USE ORBI app to set it up.
- Jjersey63May 20, 2022Apprentice
So the factory reset seemed to work but I never did get the satellites to sync. I spent enough hours on this that purchasing a new setup was warranted. 🙂
