iBRED
Mar 06, 2021Aspirant
LOST WIFI on RBR853
Hi, I have a RBK853 system and everything worked fine since yestarday when all wifi devices dropped of. I can't connect any device to the system. My phone says "no internet connection".. I ch...
- Mar 08, 2021
You are probably missing a security setting or using slightly different secure method for authentication on the new vs old SSIDs. This is a common thing that gets missed. You must have identical security, auth settings on the old and new systems. Even then, some devices will get errors or be unreliable until you "forget the network" and re-authenticate to the new SSID even with the same name.
But most devices will find the new network as long as all settings are identical.
Also, many people are experiencing DNS issues with RBR853 systems like yours - it's a DNS problem that has not yet been fixed by Netgear support. This could be part of your problem with some devices not connecting, or that they connect but communciations is unreliable.
Mar 06, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
- iBREDMar 07, 2021Aspirant
Firmware Version: v.3.2.16.22_1.4.9
House: 1700 Sq Ft
I have 2 satellites and the distance between router and them is 10 ft - 12 ft.
I'm using manual channel: 1
Only one Wifi Neighbors.
I disabled "Enable 20/40 MHz Coexistence".
WMM enabled for both 2.4GHz and 5 GHz.
Armor is not activated.
As additional information, I have 30 devices for smart home automation, and all these are connected to WiFI 2.4GHz. For each one of them I reserved a specific IP Address based on MAC Address. Could this be a problem?- FURRYe38Mar 07, 2021Guru - Experienced User
iBRED wrote:Firmware Version: v.3.2.16.22_1.4.9
You can try to update later on....
House: 1700 Sq Ft For this size of home, I would try with the RBR and just 1 RBS. Two maybe too much.
I have 2 satellites and the distance between router and them is 10 ft - 12 ft. This is too close. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
As additional information, I have 30 devices for smart home automation, and all these are connected to WiFI 2.4GHz. For each one of them I reserved a specific IP Address based on MAC Address. Could this be a problem?- iBREDMar 08, 2021Aspirant
My mistake about the distance between RBR and RBS. It is 10 m, not 10 ft.
Initially I bought only 1 Satellite and I didn’t have good coverage and I bought one more 2 month later. The house has 2 floors and it is full concreate and I’m using one on each floor. One of satellites is connected by cable.
I have one more information: I’ve change the SSID and I’m able to connect to WIFI network without problem. Changing SSID means that the other 30+ devices are not connected… I can change the SSID for all devices, but I don’t want to do this very often.
