iBRED's avatar
iBRED
LOST WIFI on RBR853
Hi,   I have a RBK853 system and everything worked fine since yestarday when all wifi devices dropped of. I can't connect any device to the system. My phone says "no internet connection"..   I ch...
  • DNS_PROBE_FAIL's avatar
    Mar 08, 2021
    You are probably missing a security setting or using slightly different secure method for authentication on the new vs old SSIDs.  This is a common thing that gets missed.  You must have identical security, auth settings on the old and new systems.  Even then, some devices will get errors or be unreliable until you "forget the network" and re-authenticate to the new SSID even with the same name.
    But most devices will find the new network as long as all settings are identical.
    Also, many people are experiencing DNS issues with RBR853 systems like yours - it's a DNS problem that has not yet been fixed by Netgear support.  This could be part of your problem with some devices not connecting, or that they connect but communciations is unreliable.
