EyalS
Jul 23, 2020Tutor
Low network speed on one satellite (out of 2) - Orbi WiFi 6 System (RBK853) AX6000
When connected to one of the satellites, either WIRED or wireless, I'm getting a maximum of 5mbps. Tested on a desktop with https://www.speedtest.net/. When replacing the satellite with a switch, I'...
- Jul 23, 2020
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat are you results of the other RBS?
Press the back reset button for 15 seconds then release.
Jul 23, 2020Guru - Experienced User
