EyalS's avatar
EyalS
Tutor
Jul 23, 2020
Low network speed on one satellite (out of 2) - Orbi WiFi 6 System (RBK853) AX6000
When connected to one of the satellites, either WIRED or wireless, I'm getting a maximum of 5mbps. Tested on a desktop with https://www.speedtest.net/. When replacing the satellite with a switch, I'...
  • FURRYe38's avatar
    Jul 23, 2020
    What are you results of the other RBS?
    Press the back reset button for 15 seconds then release.
