weisskrispies
Aug 17, 2021Tutor
Lower DL Speeds & Frequent Disconnects After Firmware Update to V4.6.3.7
Hello, I have a RBR750 Router + Mesh System (3 satellites) and ever since updating to the new firmware in July (V4.6.3.7) I've had persistently slower DL speeds (from 900 to ~600 Mbps) and the router...
- Aug 18, 2021
NG doesn't let us know when new Fw is coming out so will have to be patient. Hopefully sooner then later.
Aug 17, 2021Guru - Experienced User
This is a known issue that NG is aware of. It effects the speed results on the RBRs internal speed test app.
Use a external speed test app with a wired PC and you should see near 900Mpbs if that what you pay for from your ISP.
Also disable AX mode on the RBR. Users have posted this is helping there systems in mean time.
Hopefully should be fixed in next FW update. Please be patient.
- weisskrispiesAug 18, 2021Tutor
Thanks. Is the just pertaining to the bandwidth issue, or does it also result in the devices consistently resetting and losing signal?
- FURRYe38Aug 18, 2021Guru - Experienced User
Both.
Ah good to know, thanks for the follow up.
Is there any estimate on when the next FW update will be? This is a pretty bail #fail.
