weisskrispies
Aug 17, 2021Tutor
Lower DL Speeds & Frequent Disconnects After Firmware Update to V4.6.3.7
Hello, I have a RBR750 Router + Mesh System (3 satellites) and ever since updating to the new firmware in July (V4.6.3.7) I've had persistently slower DL speeds (from 900 to ~600 Mbps) and the router...
- Aug 18, 2021
NG doesn't let us know when new Fw is coming out so will have to be patient. Hopefully sooner then later.
weisskrispies
Aug 18, 2021Tutor
Thanks. Is the just pertaining to the bandwidth issue, or does it also result in the devices consistently resetting and losing signal?
Aug 18, 2021Guru - Experienced User
Both.
- weisskrispiesAug 18, 2021Tutor
Ah good to know, thanks for the follow up.
Is there any estimate on when the next FW update will be? This is a pretty bail #fail.
- FURRYe38Aug 18, 2021Guru - Experienced User
