Dehart
Mar 20, 2021Initiate
Mac address flipping on Orbi Satellites
I have the new Orbi RBR850 (AX-6000) with two satellites. I upgraded from the RBR50 as I had no issues with them. The new router was not cheap and it came at the cost of almost $1200.00 after few wee...
raven_au
Aug 12, 2021Virtuoso
Ragar99 wrote:I don't think I was clear, only two IPs flips MACs. Those IPs are of the two Orbi Satellites. Are you saying this is potentially caused by phones that are connected to them?
More or less, yes, possibly.
Those private MAC addresses must be coming from somewhere and we know phones and some other cases use these private MAC addresses. I certainly was surprised when I started seeing them show up in my clients list since O know the MAC addresses of my devices.
We don't know how Orbi handles ARP, it's a pretty complicated situation if you think about what has to happen.
There are 4 MAC addresses involved, the source MAC, the MAC of the source side of the Orbi, the destination MAC address and the destination side MAC address of the Orbi.
If a device on one side of a satelite wants the IP address of a device on the other side of a satelite then the satelite needs to respond to the ARP request either with the IP address of the device on the other side or with it's own address if it's behaving like a proxy.
It's complicated by the presence of wireless too, I also don't know how that's handled, maybe the Orbi doesn't need to proxy or pass the ARP responses on becuase it's a wireless broadcast that can bee seen by the station that wants it, but that's questionable since a device on the other side of a satelite might be too far away to see the broadcast, so trying to work out if what your seeing is a problem, a bug, or just logging noise is hard to know.
We just don't know what happens with this and given the stellar Orbi firware it's quite possible there's a bug (or three) in there.
It's probably worth working out which devices on the network are usmg these MAC addresses if any ... just so you know.
datentod
Dec 29, 2021Aspirant
Seeing same thing here... I have RBR750 with 2 Satelites(RBS750). One satelite is through wired backhaul(192.168.0.72, true arp 6c:cd:d6:de:78:3b). The issue only occured through wired backhaul. Also the wired backhaul satelite dosent show up in the web interface but works fine.. My setup is Orbi in AP mode with pfsense router and managed 10g switch(Ubiquiti Networks edgeswitch 16-xg). I tried everything, resetting to factory, syncing wireless sat 1st, etc,etc. Firmware is V4.6.5.14_2.0.54. Netgear support is useless, thousands blown on this product!
From pfsense router logs:
Dec 29 19:52:18 router kernel: arp: 192.168.0.72 moved from 6e:cd:d6:de:78:3e to 54:e0:19:a9:20:a7 on ix0
Dec 29 19:52:44 router kernel: arp: 192.168.0.72 moved from 6e:cd:d6:de:78:3e to 54:e0:19:a9:20:a7 on ix0
Dec 29 19:52:55 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6c:cd:d6:de:78:3b on ix0
Dec 29 19:53:18 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 19:53:44 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 19:54:30 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6e:cd:d6:de:78:3e on ix0
Dec 29 19:54:38 router kernel: arp: 192.168.0.72 moved from 6e:cd:d6:de:78:3e to 6c:cd:d6:de:78:3b on ix0
Dec 29 19:54:48 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 19:55:22 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6c:cd:d6:de:78:3b on ix0
Dec 29 19:55:23 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 6e:cd:d6:de:78:3e on ix0
Dec 29 19:55:44 router kernel: arp: 192.168.0.72 moved from 6e:cd:d6:de:78:3e to 54:e0:19:a9:20:a7 on ix0
Dec 29 19:55:55 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6c:cd:d6:de:78:3b on ix0
Dec 29 19:56:18 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 19:56:25 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6c:cd:d6:de:78:3b on ix0
Dec 29 19:56:45 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 19:57:28 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6e:cd:d6:de:78:3e on ix0
Dec 29 19:57:36 router kernel: arp: 192.168.0.72 moved from 6e:cd:d6:de:78:3e to 6c:cd:d6:de:78:3b on ix0
Dec 29 19:57:48 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 19:57:52 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6c:cd:d6:de:78:3b on ix0
Dec 29 19:58:18 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 19:58:22 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6e:cd:d6:de:78:3e on ix0
Dec 29 19:58:35 router kernel: arp: 192.168.0.72 moved from 6e:cd:d6:de:78:3e to 6c:cd:d6:de:78:3b on ix0
Dec 29 19:58:48 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 19:58:52 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6c:cd:d6:de:78:3b on ix0
Dec 29 19:59:18 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 19:59:29 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6c:cd:d6:de:78:3b on ix0
Dec 29 19:59:48 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 19:59:51 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6c:cd:d6:de:78:3b on ix0
Dec 29 20:00:18 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 20:01:00 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6e:cd:d6:de:78:3e on ix0
Dec 29 20:01:04 router kernel: arp: 192.168.0.72 moved from 6e:cd:d6:de:78:3e to 6c:cd:d6:de:78:3b on ix0
Dec 29 20:01:08 router kernel: arp: 192.168.0.72 moved from 6e:cd:d6:de:78:3e to 6c:cd:d6:de:78:3b on ix0
Dec 29 20:01:18 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 20:01:48 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 20:01:56 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6e:cd:d6:de:78:3e on ix0
Dec 29 20:02:08 router kernel: arp: 192.168.0.72 moved from 6e:cd:d6:de:78:3e to 6c:cd:d6:de:78:3b on ix0
Dec 29 20:02:18 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 20:02:23 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 20:02:34 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6c:cd:d6:de:78:3b on ix0
Dec 29 20:02:48 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 20:04:04 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6c:cd:d6:de:78:3b on ix0
Dec 29 20:04:05 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 6e:cd:d6:de:78:3e on ix0
Dec 29 20:04:13 router kernel: arp: 192.168.0.72 moved from 6e:cd:d6:de:78:3e to 6c:cd:d6:de:78:3b on ix0
Dec 29 20:04:18 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 20:04:48 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 20:05:01 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6e:cd:d6:de:78:3e on ix0
Dec 29 20:05:19 router kernel: arp: 192.168.0.72 moved from 6e:cd:d6:de:78:3e to 54:e0:19:a9:20:a7 on ix0
Dec 29 20:05:22 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6c:cd:d6:de:78:3b on ix0
Dec 29 20:05:48 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 20:06:00 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6c:cd:d6:de:78:3b on ix0
Dec 29 20:06:18 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
Dec 29 20:06:24 router kernel: arp: 192.168.0.72 moved from 54:e0:19:a9:20:a7 to 6c:cd:d6:de:78:3b on ix0
Dec 29 20:06:48 router kernel: arp: 192.168.0.72 moved from 6c:cd:d6:de:78:3b to 54:e0:19:a9:20:a7 on ix0
- CrimpOnDec 29, 2021Guru - Experienced User
Can you describe the cabling that is connecting the pfSense, Edgeswith, Orbi router, and wired Orbi satellite?
I have a suspicion that the Orbi Attached Devices display may not be picking up the wired satellite because it is connected through the WAN port rather than through one of the LAN ports.
The WiFi ports defintely present multiple MAC addresses. That is how they distinguish between SSID's (different MAC for primary and guest networks). I cannot think of a reason for the ethernet port to have multiple MAC addresses.
