Bakermama
Dec 03, 2020Initiate
Macbook Pro suddenly very slow on RBR750
Not techie, so please bear with me! I installed the RBR750 mesh system with 2 satellites in early Sept. Wired it to the ATT modem we already had, and the system has worked great until about Than...
Dec 03, 2020Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Is this the only device experiencing this?
Built in router here? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
