Bakermama
Dec 03, 2020Initiate
Macbook Pro suddenly very slow on RBR750
Not techie, so please bear with me! I installed the RBR750 mesh system with 2 satellites in early Sept. Wired it to the ATT modem we already had, and the system has worked great until about Than...
Bakermama
Thanks for the quick response.
Firmware Version is V3.2.16.6_1.4.4. I don't know if this was what was installed in the 10 weeks or so that the macbook worked just fine, or if it was updated when I checked for updated firmware as one of my first thoughts about trouble shooting last week.
To be clear, the only device that is having a problem is the macbook pro. And that device worked just fine for 10 weeks or so from install until about Thanksgiving. The macbook is circa 2015 but we've updated software so it is current.
Have done the power off of main and satellites multiple times, with at least 1 min but usually more like 5 min break. I plug in the satellites first and then the router--is that order correct?
The macbook has demonstrated the same speed issue when wirelessless on the main router or satellites. I don't think I have any cables to do a wired connection.
Modem is ARRIS BGW 210-700 from ATT. I have not done the bridge or pass through modification. Not a techie as I said, so when I unboxed the orbi and connected it, all worked just fine on all devices for weeks until last week. And frankly, since all the other devices, including a work from home computer, are working ok, I am reluctant to make a lot of changes when IT WAS WORKING last week. I'm worried I will mess up the rest of the accesses!
Other ideas?
Thanks
Dec 03, 2020Guru - Experienced User
Possible something wrong with the Mac Pro. Might contact Apple and check with them. If other devices are working fine and the Pro isn't, I would review whats going on with the Pro.
