Cpooledds
Dec 10, 2022Aspirant
Magenta light once per day
I have a netgear orbi 843 and it drops internet once per day. I have gigabit fiber coming into the house with a small modem box on the wall connected to my router with a cat6a cable. I have an old zyx...
Dec 10, 2022Guru - Experienced User
Front PINK LED means that the RBR has lost the connection from the ISP modem/ONT or the modem/ONT has lost it's connection to the ISP service this not giving services to the RBR which it's detecting and giving that indication. I would contact the ISP to review there logs when you see this on the RBR and see if they notice anything in this time frame.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Mikey94025
Dec 10, 2022Hero
The Orbi should be able to the same job as your old router, and do a better job at it. The Orbi should not be at fault for losing connectivity with your Orbi.
That said, if you only need Orbi for better wireless coverage then you could try putting your old router back in and setting your Orbi to Access Point (AP) mode. That test would add further confidence that the issue is not with your ISP but something between the Orbi->ISP connection.
