Strahan201
Oct 09, 2022Aspirant
Main unit is secured, but satellite is not
Hello. Title pretty much says it all. I noticed today that I have two SSIDs showing; they are both the same name, but one is secured and the other is not. I saw a thread on here for a similar issu...
Oct 09, 2022Guru - Experienced User
Where are you seeing this at? Provide a screen capture?
Did you update the RBS first then RBR lastly?
Has a factory reset and setup from scratch been performed since last update?
- Strahan201Oct 15, 2022Aspirant
Sorry, got busy with work and other things and totally forgot to deal with this issue, lol.
FURRYe38 wrote:Where are you seeing this at? Provide a screen capture?
I first noticed it when I went to connect my phone to wifi:
I wasn't aware one can update them independently. I just logged into the control panel, clicked Advanced then Administration then Firmware Update. I only see RBR750 there, that's it. The satellite is not listed.
No, I have not done the factory reset, that's a good idea. I'll give that a whirl.
- CrimpOnOct 16, 2022Guru - Experienced User
Yes, the iPhone definitely thinks there is a WiFi access point with that name that is "open":
I would attempt to diagnose this with a "WiFi Analyzer" application. There are many available for Android phones/tablets and for Windows, such as WiFi Info View from Nirsoft. These apps list each WiFi access point separately by hardware MAC address, so the "open" access point can be easily identified.
- Strahan201Oct 20, 2022Aspirant
CrimpOn wrote:
Strahan201 wrote:I first noticed it when I went to connect my phone to wifi:
Yea, I have Wifi Analyzer Premium from olgor.com, it's a great tool. I used it to determine that the Orbi satellite was the one broadcasting the unsecured network.
